Constructing elimination trees for sparse unsymmetric matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
The elimination tree model for unsymmetric matrices and an algorithm for constructing it have been recently proposed [Eisenstat and Liu, SIAM J. Matrix Anal. Appl., 26 (2005) and 29 (2008)]. The construction algorithm is of time complexity ${\mathcal O}(mn)$ for an $n\times n$ unsymmetric matrix having $m$ nonzeros. We propose another algorithm with a time complexity of ${\mathcal O}(m\log n)$.
RR-7549.pdf (627.43 Ko) Télécharger le fichier
inria-00567970 , version 1 (22-02-2011)
inria-00567970 , version 2 (23-02-2011)
inria-00567970 , version 3 (28-10-2011)
inria-00567970 , version 4 (04-10-2012)
  • HAL Id : inria-00567970 , version 2
Kamer Kaya, Bora Uçar. Constructing elimination trees for sparse unsymmetric matrices. [Research Report] RR-7549, 2011. ⟨inria-00567970v2⟩
Collections
INRIA-RRRT
382 Consultations
1739 Téléchargements
