Sparse representations in unions of bases - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Information Theory Année : 2003
The purpose of this correspondence is to generalize a result by Donoho and Huo and Elad and Bruckstein on sparse representations of signals in a union of two orthonormal bases for R^N. We consider general (redundant) dictionaries for R^N, and derive sufficient conditions for having unique sparse representations of signals in such dictionaries. The special case where the dictionary is given by the union of L \ge 2 orthonormal bases for R^N is studied in more detail. In particular, it is proved that the result of Donoho and Huo, concerning the replacement of the \ell^0 optimization problem with a linear programming problem when searching for sparse representations, has an analog for dictionaries that may be highly redundant.
MultiONB-final-copyrighted.pdf (140.71 Ko) Télécharger le fichier
inria-00570057 , version 1 (26-02-2011)
Rémi Gribonval, Morten Nielsen. Sparse representations in unions of bases. IEEE Transactions on Information Theory, 2003, 49 (12), pp.3320--3325. ⟨10.1109/TIT.2003.820031⟩. ⟨inria-00570057⟩
223 Consultations
639 Téléchargements
