Multi-source TDOA estimation in reverberant audio using angular spectra and clustering - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
In this article, we consider the problem of estimating the time differences of arrival (TDOAs) of multiple sources from two-channel reverberant audio mixtures. This is commonly achieved using clustering or angular spectrum-based methods. These methods are limited in that they typically affect the same weight to the spatial information provided by all time-frequency bins and rely on a binary activation model of the sources. Moreover, few experimental comparisons of different methods have been carried out so far. We introduce two new groups of TDOA estimation methods. First, we propose a time-frequency weighting procedure based on a form of signal-to-noise-ratio (SNR) that was shown to be efficient for instantaneous mixtures. Second, we introduce new clustering algorithms based on the assumption that all sources can be active in each time-frequency bin. We also study a two-step procedure combining angular spectra and clustering and conduct a large-scale experimental evaluation of the proposed and existing methods. The best average localization performance is achieved by a variant of the generalized cross-correlation with phase transform (GCC-PHAT) method without subsequent clustering. Moreover, one of the SNR-based methods we propose outperforms this method for small microphone spacing.
Dans cet article, nous considérons le problème d'estimation des différences de temps d'arrivée (TDOAs) de plusieurs sources sonores dans un enregistrement stéréophonique en environnement réverbérant. Ce problème est communément traité par des méthodes de type clustering ou spectre angulaire. Ces méthodes sont limitées par le fait qu'elle affectent typiquement le même poids à l'information spatiale issue de tous les points temps-fréquence et qu'elles se basent sur un modèle binaire d'activation des sources. De plus, peu de comparaisons expérimentales ont été effectuées jusqu'à présent. Premièrement, nous proposons une procédure de pondération temps-fréquence basée sur une forme de rapport signal-à-bruit (RSB) dont l'efficacité a été montrée pour des mélanges instantanés. Deuxièmement, nous introduisons de nouveaux algorithmes de clustering basés sur l'hypothèse que toutes les sources peuvent être actives en chaque point temps-fréquence. Nous étudions également une procédure en deux étapes combinant le spectre angulaire et le clustering et nous menons une évaluation expérimentale à grande échelle des méthodes proposées et existantes. En moyenne, les meilleures performances de localisation ont été obtenues par une version de GCC-PHAT (Generalized Cross Correlation with Phase Transform) sans avoir recours au clustering. De plus, une des méthodes basées sur le RSB que nous proposons se révèle plus performante que cette dernière lorsque la distance entre les microphones est petite.
RR-7566.pdf (595.55 Ko) Télécharger le fichier
inria-00576297 , version 1 (14-03-2011)
inria-00576297 , version 2 (18-04-2011)
inria-00576297 , version 3 (11-10-2011)
  • HAL Id : inria-00576297 , version 2
Charles Blandin, Alexey Ozerov, Emmanuel Vincent. Multi-source TDOA estimation in reverberant audio using angular spectra and clustering. [Research Report] RR-7566, 2011, pp.22. ⟨inria-00576297v2⟩
Collections
INRIA-RRRT
482 Consultations
1543 Téléchargements
