Bayesian multifractal signal denoising - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This work presents an approach for signal/image denoising in a semi-parametric frame. Our model is a wavelet-based one, which essentially assumes a minimal local regularity. This assumption translates into constraints on the multifractal spectrum of the signals. Such constraints are in turn used in a Bayesian framework to estimate the wavelet coefficients of the original signal from the noisy ones. Our scheme is well adapted to the processing of irregular signals, such as (multi-)fractal ones, and is potentially useful for the processing of e.g. turbulence, bio-medical or seismic data.
Bayesian-multifractal-signal-denoising.pdf (161.29 Ko) Télécharger le fichier
inria-00576482 , version 1 (15-03-2011)
  • HAL Id : inria-00576482 , version 1
Jacques Lévy Véhel, Pierrick Legrand. Bayesian multifractal signal denoising. ICASSP03, IEEE International Conference on Acoustics, Speech, and Signal Processing, Apr 2003, Hong-Kong, China. ⟨inria-00576482⟩
188 Consultations
326 Téléchargements
