A Theory of Dictionary Attacks and its Complexity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2004
We consider the problem of automating proofs of cryptographic protocols when some data, like poorly chosen passwords, can be guessed by dictionary attacks. First, we define a theory of these attacks: we introduce an inference system modeling the guessing capabilities of an intruder. This system extends the classical Dolev-Yao rules. Using proof rewriting techniques, we show a locality lemma for our inference system which yields the PTIME-completeness of the deduction problem. This result is lifted to the simultaneous solving of intruder deduction constraints with variables. Constraint solving is the basis of a NP algorithm for the protocol insecurity problem in the presence of dictionary attacks, assuming a bounded number of sessions. This extends the classical NP-completeness result for the Dolev-Yao model. We illustrate the procedure with examples of published protocols. The model and decision algorithm have been validated on some examples in a prototype implementation.
DJ-csfw2004.pdf (208.29 Ko) Télécharger le fichier
inria-00579014 , version 1 (22-03-2011)
  • HAL Id : inria-00579014 , version 1
Stéphanie Delaune, Florent Jacquemard. A Theory of Dictionary Attacks and its Complexity. 17th IEEE Computer Security Foundations Workshop (CSFW), Jun 2004, Asilomar, Pacific Grove, United States. pp.2-15. ⟨inria-00579014⟩
101 Consultations
396 Téléchargements
