Comparing archival policies for Blue Waters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
This paper introduces two new tape archival policies that can im- prove tape archive performance in certain regimes, compared to the classical RAIT (Redundant Array of Independent Tapes) policy. The first policy, PAR- ALLEL, still requires as many parallel tape drives as RAIT but pre-computes large data stripes that are written contiguously on tapes to increase write/read performance. The second policy, VERTICAL, writes contiguous data into a single tape, while updating error correcting information on the fly and delaying its archival until enough data has been archived. This second approach reduces the number of tape drives used for every user request to one. The performance of the three RAIT, PARALLEL and VERTICAL policies is assessed through extensive simulations, using a hardware configuration and a distribution of I/O requests similar to these expected on the Blue Waters system. These simulations show that VERTICAL is the most suitable policy for small files, whereas PARALLEL must be used for files larger than 1 GB. We also demonstrate that RAIT never outperforms both proposed policies, and that a heterogeneous policies mixing VERTICAL and PARALLEL performs 10 times better than any other policy.
RR-7583.pdf (472.69 Ko) Télécharger le fichier
inria-00580599 , version 1 (28-03-2011)
inria-00580599 , version 2 (29-03-2011)
  • HAL Id : inria-00580599 , version 1
Franck Cappello, Mathias Jacquelin, Loris Marchal, Yves Robert, Marc Snir. Comparing archival policies for Blue Waters. [Research Report] RR-7583, 2011. ⟨inria-00580599v1⟩
Collections
INRIA-RRRT
418 Consultations
293 Téléchargements
