What Topology tells us about Diagnosability in Partial Order Semantics
From a partial observation of the behaviour of a labeled Discrete Event System, \emph{fault diagnosis} strives to determine whether or not a given ''invisible'' fault event has occurred. The \emph{diagnosability problem} can be stated as follows: does the labeling allow for an outside observer to determine the occurrence of the fault, no later than a bounded number of events after that unobservable occurrence ? When this problem is investigated in the context of concurrent systems, partial order semantics adds to the difficulty of the problem, but also provides a richer and more complex picture of observation and diagnosis. In particular, it is crucial to clarify the intuitive notion of ''\emph{time after fault occurrence}". To this end, we will use a unifying metric framework for event structures, providing a general topological description of diagnosability in both sequential and nonsequential semantics for Petri nets.
Déscription topologique de diagnosticabilité dans des sémantiques séquentielles et non-séquentielles des Réseaux de Petri.
