Algorithm engineering for optimal alignment of protein structure distance matrices - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Optimization Letters Année : 2011
Protein structural alignment is an important problem in computational biology. In this paper, we present first successes on provably optimal pairwise alignment of protein inter-residue distance matrices, using the popular Dali scoring function. We introduce the structural alignment problem formally, which enables us to express a variety of scoring functions used in previous work as special cases in a unified framework. Further, we propose the first mathematical model for computing optimal structural alignments based on dense inter-residue distance matrices. We therefore reformulate the problem as a special graph problem and give a tight integer linear programming model. We then present algorithm engineering techniques to handle the huge integer linear programs of real-life distance matrix alignment problems. Applying these techniques, we can compute provably optimal Dali alignments for the very first time.
paper.pdf (293.24 Ko) Télécharger le fichier
inria-00586067 , version 1 (15-04-2011)
Inken Wohlers, Rumen Andonov, Gunnar W. Klau. Algorithm engineering for optimal alignment of protein structure distance matrices. Optimization Letters, 2011, ⟨10.1007/s11590-011-0313-3⟩. ⟨inria-00586067⟩
142 Consultations
238 Téléchargements
