Supporting both exploratory design and power of action with a new property sheet - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
Graphical interaction designers often make tradeoffs between supporting exploratory design and power of action. In this paper, we describe a new property sheet and a set of interaction that aims at supporting both. Thanks to a new visualization of properties and values, and modeless, example-based interaction and selection, designers can make an opportunistic use of implicit groups to augment their power of action.
WIP_CHI-submitted.pdf (790.44 Ko) Télécharger le fichier
inria-00586099 , version 1 (15-04-2011)
  • HAL Id : inria-00586099 , version 1
Raphaël Hoarau, Stéphane Conversy. Supporting both exploratory design and power of action with a new property sheet. 2011. ⟨inria-00586099⟩
106 Consultations
81 Téléchargements
