SAIA: safe deployment of sensors based real time application - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
SAIA is a model based architecture for the development of sensors based real time applications. This paper presents the mandatory concepts to manage the extra-functional properties relating to the communication with the physical environment. Moreover, it proposes an implementation of these concepts and then a way to realize a safe application deployment.
deantoni_babau_MAMAS.pdf (195.11 Ko) Télécharger le fichier
inria-00587178 , version 1 (19-04-2011)
  • HAL Id : inria-00587178 , version 1
Julien Deantoni, Jean-Philippe Babau. SAIA: safe deployment of sensors based real time application. Workshop on Models and Analysis for Automotive Systems (held in conjunction with RTSS), Dec 2006, Rio de Janeiro, Brazil. ⟨inria-00587178⟩
146 Consultations
62 Téléchargements
