SensLAB Very Large Scale Open Wireless Sensor Network Testbed - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper presents a precise description of SensLAB: Very Large Scale Open Wireless Sensor Network Testbed that has been developed and deployed in order to allow the evaluation of scalable wireless sensor network protocols and applications. SensLAB's main and most important goal is to o er an accurate open access multi-users scienti c tool to support the design, development, tuning, and experimentation of real large-scale sensor network applications. The SensLAB testbed is composed of 1024 nodes and it is distributed among 4 sites. Two sites o er access to mobile nodes. Every sensor node is also able to be con gured as a sink node and can exchange data with any other sink node of the whole SensLAB testbed (locally or remotely) or any computer on the Internet. The hardware designed on purpose and software architectures that allow to reserve, con gure, deploy embedded software, boot wireless sensor nodes and gather experimental data and monitoring information are described in details. We also present short demonstration examples to illustrate the use of the SensLAB testbed.
senslab.pdf (1.57 Mo) Télécharger le fichier
inria-00587862 , version 1 (21-04-2011)
  • HAL Id : inria-00587862 , version 1
Clément Burin Des Rosiers, Guillaume Chelius, Eric Fleury, Antoine Fraboulet, Antoine Gallais, et al.. SensLAB Very Large Scale Open Wireless Sensor Network Testbed. Proc. 7th International ICST Conference on Testbeds and Research Infrastructures for the Development of Networks and Communities (TridentCOM), Apr 2011, Shanghai, China. ⟨inria-00587862⟩
609 Consultations
853 Téléchargements
