Improvements on the Discrete Logarithm Problem in GF(p) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2011
This paper speeds up descrete logarithm algorithms in two ways. First we show how the Factorization Factory can be adapted to the discrete logarithm to drop the complexity from Lp(1/3,1.902) to Lp(1/3,1.639). Next we prove that an early abort strategy can decrease the complexity of the individual logarithm from Lp(1/3,1.447) to Lp(1/3,1.232).
hal.pdf (913.4 Ko) Télécharger le fichier
inria-00588713 , version 1 (26-04-2011)
inria-00588713 , version 2 (02-05-2011)
inria-00588713 , version 3 (14-03-2016)
  • HAL Id : inria-00588713 , version 2
Razvan Barbulescu. Improvements on the Discrete Logarithm Problem in GF(p). [Internship report] 2011. ⟨inria-00588713v2⟩
587 Consultations
470 Téléchargements
