Implicit FEM and Fluid Coupling on GPU for Interactive Multiphysics Simulation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present a method to implement on the GPU an implicit FEM solver which is fast and stable enough to handle interactions and collisions. We combine this method with GPU-based fluids and collision detection to achieve interactive multiphysics simulations entirely running on the GPU.
c96-f96_3-a528-abstract-v9.pdf (798.66 Ko) Télécharger le fichier
c96-f96_3-a528-suppvideo-v3.mp4 (48.08 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00589203 , version 1 (28-04-2011)
inria-00589203 , version 2 (05-04-2012)
Jérémie Allard, Hadrien Courtecuisse, François Faure. Implicit FEM and Fluid Coupling on GPU for Interactive Multiphysics Simulation. SIGGRAPH Talks, Aug 2011, Vancouver, Canada. pp.52, ⟨10.1145/2037826.2037895⟩. ⟨inria-00589203v1⟩
553 Consultations
1888 Téléchargements
