Using Description Logics for Indexing Audiovisual Documents - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
We address the problem of indexing broadcast audiovisual documents such as films and newscasts. Starting from a collection of shots, we aim at building automatically high-level descriptions of subsets of this collection, that can be used for annotating, indexing and accessing the documents. We propose to represent documents and high-level descriptions with the framework of description logics, enriched with temporal relations. We first define the problem as a classification problem. We then propose an algorithm to automatically classify subsequences of shots, based on a bottom-up construction of descriptions using the rule mechansim of the CLASSIC system.
cpr98.pdf (49.28 Ko) Télécharger le fichier
Format : Figure, Image
inria-00590092 , version 1 (03-05-2011)
inria-00590092 , version 2 (01-09-2014)
  • HAL Id : inria-00590092 , version 1
Jean Carrive, Francois Pachet, Rémi Ronfard. Using Description Logics for Indexing Audiovisual Documents. International Workshop on Description Logics (DL '98), Jun 1998, Trento, Italy. ⟨inria-00590092v1⟩
85 Consultations
141 Téléchargements
