Visual Servoing from Lines
We use an alternative formulation of the Euclidean Plucker coordinates to define the new normalized Plucker coordinates for alignment of lines. This concept is more relevant than usual image alignment to position a single calibrated camera with respect to a set of known 3D lines. An explicit control law is derived which realizes such a task both for one or several lines. It is tested by positioning the camera with respect to an orthogonal trihedron. This application is all the more challenging in that it requires depth to be observed. We do this by using the image projection of a laser pointer and adequately completing the control law.
Domains
Graphics [cs.GR]
Origin : Publisher files allowed on an open archive
