The Cyclope : A 6 DOF Optical Tracker Based on a Single Camera
In this paper we describe a low-cost infrared optical device capable of tracking two targets with six DOF (Degrees Of Freedom) for interaction within both desktop and large projection applications. We use off-the-shelf components for the hardware and open-source libraries for the software.
TheCyclopeTracker.pdf (57.88 Ko)
Télécharger le fichier
Format : Figure, Image
