Multiple contour extraction from graylevel images using an artificial neural network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue IEEE Transactions on Image Processing Année : 2006
For active contour modeling (ACM), we propose a novel self-organizing map (SOM)-based approach, called the batch-SOM (BSOM), that attempts to integrate the advantages of SOM- and snake-based ACMs in order to extract the desired contours from images. We employ feature points, in the form of an edge-map (as obtained from a standard edge-detection operation), to guide the contour (as in the case of SOM-based ACMs) along with the gradient and intensity variations in a local region to ensure that the contour does not "leak" into the object boundary in case of faulty feature points (weak or broken edges). In contrast with the snake-based ACMs, however , we do not use an explicit energy functional (based on gradient or intensity) for controlling the contour movement. We extend the BSOM to handle extraction of contours of multiple objects, by splitting a single contour into as many subcontours as the objects in the image. The BSOM and its extended version are tested on synthetic binary and gray-level images with both single and multipleobjects. We also demonstrate the efficacy of the BSOM on images of objects having both convex and nonconvex boundaries. The results demonstrate the superiority of the BSOM over others. Finally, we analyze the limitations of the BSOM.
RamyaIP2006.pdf (479.07 Ko) Télécharger le fichier
inria-00590203 , version 1 (16-06-2011)
Yedatore-Venkatakrishnaiya Venkatesh, S.Kumar Raja, Narasimha Ramya. Multiple contour extraction from graylevel images using an artificial neural network. IEEE Transactions on Image Processing, 2006, 15 (4), pp.892--899. ⟨10.1109/TIP.2005.863934⟩. ⟨inria-00590203⟩
44 Consultations
566 Téléchargements
