Feature-Based Vector Simulation of Water Waves
We present a method for simulating local water waves caused by obstacles in water streams for real-time graphics applications. Given a low-resolution water surface and velocity field, our method is able to decorate the input water surface with high resolution detail for the animated waves around obstacles. We construct and animate a vector representation of the waves. It is then converted to feature-aligned meshes for capturing the surfaces of the waves. Results demonstrate that our method has the benefits of real-time performance and easy controllability. The method also fits well into a state-of-the-art river animation system.
Domains
Graphics [cs.GR]
vecsim.pdf (1.69 Mo)
Télécharger le fichier
waves_xvid.avi (16.08 Mo)
Origin : Publisher files allowed on an open archive
Format : Figure, Image
Format : Video
