Statistical Model Checking: An Overview - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Axel Legay
  • Fonction : Auteur
  • PersonId : 861400
Saddek Bensalem
Quantitative properties of stochastic systems are usually specified in logics that allow one to compare the measure of executions satisfying certain temporal properties with thresholds. The model checking problem for stochastic systems with respect to such logics is typically solved by a numerical approach [31,8,35,22,21,5] that iteratively computes (or approximates) the exact measure of paths satisfying relevant subformulas; the algorithms themselves depend on the class of systems being analyzed as well as the logic used for specifying the properties. Another approach to solve the model checking problem is to simulate the system for finitely many executions, and use hypothesis testing to infer whether the samples provide a statistical evidence for the satisfaction or violation of the specification. In this tutorial, we survey the statistical approach, and outline its main advantages in terms of efficiency, uniformity, and simplicity.
RV10-2.pdf (216.04 Ko) Télécharger le fichier
inria-00591593 , version 1 (09-05-2011)
Axel Legay, Benoît Delahaye, Saddek Bensalem. Statistical Model Checking: An Overview. Runtime Verification, Nov 2010, Malta, Malta. ⟨10.1007/978-3-642-16612-9_11⟩. ⟨inria-00591593⟩
269 Consultations
530 Téléchargements
