Revisiting Monte-Carlo Tree Search on a Normal Form Game: NoGo - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We revisit Monte-Carlo Tree Search on a recent game, termed NoGo. Our goal is to check if known results in Computer-Go and various other games are general enough for being applied directly on a new game. We also test if the known limitations of Monte-Carlo Tree Search also hold in this case and which improvements of Monte-Carlo Tree Search are necessary for good performance and which have a minor effect. We also tested a generic Monte-Carlo simulator, designed for "no more moves" games.
mogonogo.pdf (151.69 Ko) Télécharger le fichier
inria-00593154 , version 1 (13-05-2011)
C.-W. Chou, Olivier Teytaud, Shi-Jim Yen. Revisiting Monte-Carlo Tree Search on a Normal Form Game: NoGo. EvoGames 2011, Apr 2011, Turino, Italy. pp.73-82, ⟨10.1007/978-3-642-20525-5⟩. ⟨inria-00593154⟩
156 Consultations
832 Téléchargements
