A Modeling Approach based on UML/MARTE for GPU Architecture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Nowadays, the High Performance Computing is part of the context of embedded systems. Graphics Processing Units (GPUs) are more and more used in acceleration of the most part of algorithms and applications. Over the past years, not many efforts have been done to describe abstractions of applications in relation to their target architectures. Thus, when developers need to associate applications and GPUs, for example, they find difficulty and prefer using API for these architectures. This paper presents a metamodel extension for MARTE profile and a model for GPU architectures. The main goal is to specify the task and data allocation in the memory hierarchy of these architectures. The results show that this approach will help to generate code for GPUs based on model transformations using Model Driven Engineering (MDE).
sympa2011.pdf (563.1 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
inria-00593863 , version 1 (19-05-2011)
  • HAL Id : inria-00593863 , version 1
  • ARXIV : 1105.4424
Antonio Wendell de Oliveira Rodrigues, Frédéric Guyomarc'H, Jean-Luc Dekeyser. A Modeling Approach based on UML/MARTE for GPU Architecture. Symposium en Architectures nouvelles de machines (SympA'14), May 2011, Saint Malo, France. ⟨inria-00593863⟩
167 Consultations
337 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
