Behavior Analysis of Malware by Rewriting-based Abstraction - Extended Version - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
We propose a formal approach for the detection of high-level program behaviors. These behaviors, defined as combinations of patterns in a signature, are detected by model-checking on abstracted forms of program traces. Our approach works on unbounded sets of traces, which makes our technique useful not only for dynamic analysis, considering one trace at a time, but also for static analysis, considering a set of traces inferred from a control flow graph. Our technique uses a rewriting-based abstraction mechanism, producing a high-level representation of the program behavior, independent of the program implementation. It allows us to handle similar behaviors in a generic way and thus to be robust with respect to variants. Successfully applied to malware detection, our approach allows us in particular to model and detect information leak.
fmcad-extended.pdf (256.03 Ko) Télécharger le fichier
inria-00594396 , version 1 (20-05-2011)
  • HAL Id : inria-00594396 , version 1
Philippe Beaucamps, Isabelle Gnaedig, Jean-Yves Marion. Behavior Analysis of Malware by Rewriting-based Abstraction - Extended Version. [Research Report] 2011. ⟨inria-00594396⟩
256 Consultations
134 Téléchargements
