Simple and Fast Fluids
A simple and efficient algorithm for the simulation of fluid flow directly on the GPU using a single pixel shader is proposed. By temporarily relaxing the incompressibility condition, it is possible to solve the full Navier-Stokes equations over the domain in a single pass.
PreprintSFFGuayColinEgli.pdf (1.34 Mo)
Télécharger le fichier
Format : Figure, Image
