PSPARQL Query Containment - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
Querying the semantic web is mainly done through SPARQL. This language has been studied from different perspectives such as optimization and extension. One of its extensions, PSPARQL (Path SPARQL) provides queries with paths of arbitrary length. We study the static analysis of queries written in this language, in particular, containment of queries: determining whether, for any graph, the answers to a query are contained in those of another query. Our approach consists in encoding RDF graphs as transition systems and queries as $\mu$-calculus formulas and then reducing the containment problem to testing satisfiability in the logic. We establish complexity bounds and report experimental results
PSPARQL_Query_Containment.pdf (435.31 Ko) Télécharger le fichier
inria-00598819 , version 1 (07-06-2011)
inria-00598819 , version 2 (08-06-2011)
  • HAL Id : inria-00598819 , version 1
Melisachew Wudage Chekol, Jérôme Euzenat, Pierre Genevès. PSPARQL Query Containment. [Research Report] 2011. ⟨inria-00598819v1⟩
496 Consultations
167 Téléchargements
