Leader Election : from higham-przytycka's algorithm to a gracefully degrading algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2011
The leader election problem consists in selecting a process (called leader) in a group of processes. Several leader election algorithms have been proposed in the past for ring networks, tree networks, fully connected networks or regular networks (such as tori and hypercubes). As far as ring networks are concerned, it has been shown that the number of messages that processes have to exchange to elect a leader is (n log n). The algorithm proposed by Higham and Przytycka is the best leader algorithm known so far for ring networks in terms of message complexity, which is 1.271 n log n + O(n). This algorithm uses round numbers and assumes that all processes start with the same round number. More precisely, when round numbers are not initially equal, the algorithm has runs that do not terminate. This paper presents an algorithm, based on Higham-Przytycka's technique, which allows processes to start with different round numbers. This extension is motivated by fault-tolerance with respect to initial values. While the algorithm always terminates, its message complexity is optimal, i.e., O(n log n), when the processes start with the same round number and increases up to O(n2) when all processes start with different round number values. We call graceful degradation this additional property that combines fault-tolerance (with respect to initial values) and efficiency.
PI-1980.pdf (268.66 Ko) Télécharger le fichier
inria-00605799 , version 1 (04-07-2011)
  • HAL Id : inria-00605799 , version 1
Itziar Arrieta, Federico Fariña, José Ramón G. de Mendívil, Michel Raynal. Leader Election : from higham-przytycka's algorithm to a gracefully degrading algorithm. [Research Report] PI-1980, 2011, pp.9. ⟨inria-00605799⟩
229 Consultations
299 Téléchargements
