Implicit Visibility and Antiradiance for Interactive Global Illumination - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2007
We reformulate the rendering equation to alleviate the need for explicit visibility computation, thus enabling interactive global illumination on graphics hardware. This is achieved by treating visibility implicitly and propagating an additional quantity, called antiradiance, to compensate for light transmitted extraneously. Our new algorithm shifts visibility computation to simple local iterations by maintaining additional directional antiradiance information with samples in the scene. It is easy to parallelize on a GPU. By correctly treating discretization and filtering, we can compute indirect illumination in scenes with dynamic objects much faster than traditional methods. Our results show interactive update of indirect illumination with moving characters and lights.
ImplicitVisibilityAndAntiradiance.pdf (8.15 Mo) Télécharger le fichier
DSDD07.avi (58.65 Mo) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00606794 , version 1 (19-07-2011)
Carsten Dachsbacher, Marc Stamminger, George Drettakis, Frédo Durand. Implicit Visibility and Antiradiance for Interactive Global Illumination. ACM Transactions on Graphics, 2007, Proceedings of ACM SIGGRAPH 2007, 26 (3), pp.10. ⟨10.1145/1275808.1276453⟩. ⟨inria-00606794⟩
Collections
INRIA INRIA2
279 Consultations
309 Téléchargements
