FPGA-Specific Synthesis of Loop-Nests with Pipelined Computational Cores
Increases in the capacities and features of FPGAs has opened a new perspective on their use as application accelerators. However, in order for FPGAs to be accepted is mainstream solutions, the long design cycles must be shortened by using high-level synthesis tools in the design process. Current HLS tools targeting FPGAs come with several limitations, and one of them is the efficient use of pipelined arithmetic operators, commonly encountered in high-throughput FPGA designs. We focus here on the efficient generation of FPGA-specific hardware accelerators for regular codes with perfect loop nests where inner statements are implemented as a pipelined arithmetic operator, which is often the case of scientific codes using floating-point arithmetic. We propose a semi-automatic code generation process where the arithmetic operator is identified and generated. Its pipeline information is used to reschedule the initial program execution in order to keep the operator's pipeline as ''busy'' as possible, while minimizing memory access. Next, we show how our method can be used as a tool to generate control FSMs of multiple parallel computing cores. Finally, we show that accounting for the application's accuracy needs allows designing smaller and faster operators.
L'augmentation des fonctionnalités et de la capacité des FPGAs ouvre de nouvelles perspectives pour la conception d'accélérateurs de calcul. Cependant, pour que les FPGAs soient communément acceptés, le cycle de développement -- habituellement long -- doit être réduit en utilisant des outils de synthèse de haut-niveau. Les outils actuels pour FPGAs ont de nombreuses limitations. En particulier, ils ne parviennent pas à utiliser efficacement les opérateurs arithmétiques pipelinés, fréquement utilisés dans les designs FPGAs. Dans ce rapport, nous nous intéressons à la génération efficace d'accélérateurs matériels sur FPGA, pour les codes de calcul réguliers avec des nids de boucle parfaits et des références affines, dans lesquels les affectations sont implémentées avec un noyau arithmétique pipeliné. Ce type de programme est particulièrement fréquent dans les codes de calcul scientifique en virgule flottante. Nous proposons une technique d'ordonnancement et de génération de code VHDL où le noyau arithmétique est identifié par l'utilisateur, puis généré. La profondeur de pipeline du noyau arithmétique est utilisée pour réordonnancer l'exécution du programme de façon à utiliser le pipeline de façon optimale, tout en minimisant les accès mémoires. Ensuite, nous montrons comment notre méthode peut être utilisée pour générer un automate de contrôle pour plusieurs noyaux arithmétiques fonctionnant en paralléle. Enfin, nous montrons que tenir compte du besoin en précision de l'application permet de construire des accélérateurs plus petits et plus rapides.
