VirtualEMF: a Model Virtualization Tool - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Specification of complex systems involves several heterogeneous and interrelated models. Model composition is a crucial (and complex) modeling activity that allows combining different system perspectives into a single cross-domain view. Current composition solutions fail to fully address the problem, presenting important limitations concerning efficiency, interoperability, and/or synchronization. To cope with these issues, in this demo we introduce VirtualEMF: a model composition tool based on the concept of a virtual model, i.e., a model that do not hold concrete data, but that redirects all its model manipulation operations to the set of base models from which it was generated.
ER.Demo.2011.pdf (179.95 Ko) Télécharger le fichier
inria-00609613 , version 1 (25-06-2012)
  • HAL Id : inria-00609613 , version 1
Cauê Clasen, Frédéric Jouault, Jordi Cabot. VirtualEMF: a Model Virtualization Tool. Workshops of the 30th International Conference on Conceptual Modeling (ER 2011), Oct 2011, Brussels, Belgium. ⟨inria-00609613⟩
251 Consultations
345 Téléchargements
