On the weights of affine-variety codes and some Hermitian codes
For any affine-variety code we show how to construct an ideal whose solutions correspond to codewords with any assigned weight. We use our ideal and a geometric characterization to determine the number of small-weight codewords for some families of Hermitian codes over any Fq. In particular, we determine the number of minimum-weight code- words for all Hermitian codes with d ≤ q. For such codes we also count some other small-weight codewords.
