A Proof Assistant Based Formalization of components in MDE
Model driven engineering (MDE) now plays a key role in the development of safety critical systems through the use of early validation and verification of models, and the automatic generation of software and hardware artifacts from the validated and verified models. In order to ease the integration of formal specification and verification technologies, various formalizations of the MDE technologies were proposed by different authors using term or graph rewriting, proof assistants, logical frameworks, etc. The use of components is also mandatory to improve the efficiency of system development. Invasive Software Composition (ISC) has been proposed by Assman to add a generic component structure to existing Domain Specific Modeling Languages in MDE. This approach is the basis of the ReuseWare toolset. We present in this paper an extension of a formal embedding of some key aspects of MDE in set theory in order to formalize ISC and prove the correctness of the proposed approach with respect to the conformance relation with the base metamodel. The formal embedding we rely on was developed by some of the authors and then implemented using the Calculus of Inductive Construction and the Coq proof-assistant. This work is a first step in the formalization of composable verification technologies in order to ease its integration for DSML extended with component features using ISC.
Domains
Software Engineering [cs.SE]
