On Quasi-Cyclic Codes as a Generalization of Cyclic Codes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
In this article we see quasi-cyclic codes as block cyclic codes. We generalize some properties of cyclic codes to quasi-cyclic ones such as generator polynomials and ideals. Indeed we show a one-to-one correspondence between l-quasi-cyclic codes of length m and ideals of M_l(Fq )[X]/(X^m −1). This permits to construct new classes of codes, namely quasi-BCH and quasi-evaluation codes. We study the parameters of such codes and propose a decoding algorithm up to half the designed minimum distance. We even found one new quasi-cyclic code with better parameters than known [189, 11, 125]_F4 and 48 derivated codes beating the known bounds as well.
article.pdf (210.1 Ko) Télécharger le fichier
inria-00615276 , version 1 (18-08-2011)
inria-00615276 , version 2 (25-05-2012)
  • HAL Id : inria-00615276 , version 1
  • ARXIV : 1108.3754
Morgan Barbier, Christophe Chabot, Guillaume Quintin. On Quasi-Cyclic Codes as a Generalization of Cyclic Codes. 2011. ⟨inria-00615276v1⟩
411 Consultations
831 Téléchargements
