Spatial Decision Forests for MS Lesion Segmentation in Multi-Channel Magnetic Resonance Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2011
A new algorithm is presented for the automatic segmentation of Multiple Sclerosis (MS) lesions in 3D Magnetic Resonance (MR) images. It builds on a discriminative random decision forest framework to provide a voxel-wise probabilistic classification of the volume. The method uses multi-channel MR intensities (T1, T2, and FLAIR), knowledge on tissue classes and long-range spatial context to discriminate lesions from background. A symmetry feature is introduced accounting for the fact that some MS lesions tend to develop in an asymmetric way. Quantitative evaluation of the proposed methods is carried out on publicly available labeled cases from the MICCAI MS Lesion Segmentation Challenge 2008 dataset. When tested on the same data, the presented method compares favorably to all earlier methods. In an a posteriori analysis, we show how selected features during classification can be ranked according to their discriminative power and reveal the most important ones.
Geremia-MS-NeuroImage-2011.pdf (1.75 Mo) Télécharger le fichier
inria-00616194 , version 1 (26-07-2013)
Ezequiel Geremia, Olivier Clatz, Bjoern H. Menze, Ender Konukoglu, Antonio Criminisi, et al.. Spatial Decision Forests for MS Lesion Segmentation in Multi-Channel Magnetic Resonance Images. NeuroImage, 2011, 57 (2), pp.378-390. ⟨10.1016/j.neuroimage.2011.03.080⟩. ⟨inria-00616194⟩
277 Consultations
745 Téléchargements
