Convergence Rates of Inexact Proximal-Gradient Methods for Convex Optimization - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We consider the problem of optimizing the sum of a smooth convex function and a non-smooth convex function using proximal-gradient methods, where an error is present in the calculation of the gradient of the smooth term or in the proximity operator with respect to the non-smooth term. We show that both the basic proximal-gradient method and the accelerated proximal-gradient method achieve the same convergence rate as in the error-free case, provided that the errors decrease at appropriate rates.Using these rates, we perform as well as or better than a carefully chosen fixed error level on a set of structured sparsity problems.
inexact_prox_arxiv.pdf (391.97 Ko) Télécharger le fichier
inria-00618152 , version 1 (12-09-2011)
inria-00618152 , version 2 (01-12-2011)
inria-00618152 , version 3 (01-12-2011)
  • HAL Id : inria-00618152 , version 1
  • ARXIV : 1109.2415
Mark Schmidt, Nicolas Le Roux, Francis Bach. Convergence Rates of Inexact Proximal-Gradient Methods for Convex Optimization. 2011. ⟨inria-00618152v1⟩
793 Consultations
2189 Téléchargements
