On a Geodesic Equation for Planar Conformal Template Matching
In this paper we consider planar conformal deformations, motivated by the warps that Wentworth Thompson used to deform images of one species into another. We study an equation for geodesic motion on the infinite dimensional Fréchet manifold $Con(D,R^2)$ of conformal embeddings of the disk into the plane. We demonstrate that solutions may be represented as sheets, and use the sheet ansatz to derive a numerical discretization scheme. We also show that the equation admits totally geodesic solutions corresponding to scaling and translation, but not to affine transformations.
Autre [cs.OH]
