Detecting Long Distance Conditional Correlations Between Anatomical Regions Using Gaussian Graphical Models - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The conditional correlation patterns of an anatomical shape may provide some important information on the structure of this shape. We propose to investigate these patterns by Gaussian Graphical Modelling. We design a model which takes into account both local and long-distance dependencies. We provide an algorithm which estimates sparse long-distance conditional correlations, highlighting the most significant ones. The selection procedure is based on a criterion which quantifies the quality of the conditional correlation graph in terms of prediction. The preliminary results on AD versus control population show noticeable differences.
Autre [cs.OH]
MFCA11_4_2.pdf (614.98 Ko) Télécharger le fichier
inria-00623930 , version 1 (15-09-2011)
  • HAL Id : inria-00623930 , version 1
Stéphanie Allassonnière, Pierre Jolivet, Christophe Giraud. Detecting Long Distance Conditional Correlations Between Anatomical Regions Using Gaussian Graphical Models. Proceedings of the Third International Workshop on Mathematical Foundations of Computational Anatomy - Geometrical and Statistical Methods for Modelling Biological Shape Variability, Sep 2011, Toronto, Canada. pp.111-122. ⟨inria-00623930⟩
378 Consultations
347 Téléchargements
