Extraction et caractérisation de régions saines et pathologiques à partir de micro-tomographie RX du système vasculaire cérébral
In this paper, we consider X-ray micro-tomography representing the brain vascular network. We define the local vascular territories as the regions obtained after a watershed algorithm applied on the distance map. The obtained graph is then regularized by a Markov random field approach. The optimization is performed using a graph cut algorithm. We show that the resulting segmentation exhibits three classes corresponding to normal tissue, tumour and an intermediate region.
Domains
Image Processing [eess.IV]
