An Economic Approach for Application QoS Management in Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2011
Virtualization provides increased control and flexibility in how resources are allocated to applications. However, common resource provisioning mechanisms do not fully use these advantages; either they provide limited support for applications demanding quality of service, or the resource allocation complexity is high. To address this problem we propose a novel resource management architecture for virtualized infrastructures based on a virtual economy. By limiting the coupling between the applications and the resource management, this architecture can support diverse types of applications and performance goals while ensuring an efficient resource usage. We validate its use through simple policies that scale the resource allocations of the applications vertically and horizontally to meet application performance goals.
No file
Dates and versions
inria-00625983 , version 1 (23-09-2011)
Identifiers
  • HAL Id : inria-00625983 , version 1
Cite
Stefania Victoria Costache, Nikos Parlavantzas, Christine Morin, Samuel Kortas. An Economic Approach for Application QoS Management in Clouds. 6th Workshop on Virtualization in High-Performance Cloud Computing (VHPC), Aug 2011, Bordeaux, France. ⟨inria-00625983⟩
239 View
0 Download
Share
