Gliimpse: Animating from Markup Code to Rendered Documents and Vice-Versa - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pierre Dragicevic
Fanny Chevalier
We present a quick preview technique that smoothly transitions between document markup code and its visual rendering. This technique allows users to regularly check the code they are editing in-place, without leaving the text editor. This method can complement classical preview windows by offering rapid overviews of code-to-document mappings and leaving more screen real-estate. We discuss the design and implementation of our technique.
GlimpseA.pdf (1.92 Mo) Télécharger le fichier
inria-00626259 , version 1 (24-09-2011)
  • HAL Id : inria-00626259 , version 1
Pierre Dragicevic, Stéphane Huot, Fanny Chevalier. Gliimpse: Animating from Markup Code to Rendered Documents and Vice-Versa. UIST 2011 - 24th ACM Symposium on User Interface Software and Technology, ACM SIGCHI, Oct 2011, Santa Barbara, CA, United States. ⟨inria-00626259⟩
358 Consultations
523 Téléchargements
