Explicit modeling of human-object interactions in realistic videos - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2011
We introduce an approach for learning human actions as interactions between persons and objects in realistic videos. Previous works typically represent actions with low-level features such as image gradients or optical flow. In contrast, we explicitly localize in space and track over time both the object and the person, and represent an action as the trajectory of the object wrt to the person position. Our approach relies on state-of-the-art approaches for human [32] and object detection [10] as well as tracking [39]. We show that this results in human and object tracks of sufficient quality to model and localize human-object interactions in realistic videos. Our human-object interaction features capture relative trajectory of the object wrt the human. Experimental results on the Coffee & Cigarettes [25], the video dataset of [19] and the Rochester Daily Activities dataset [29] show that (i) our explicit human-object model is an informative cue for action recognition; (ii) it is complementary to traditional low-level descriptors such as 3D-HOG extracted over human tracks. When combining our human-object interaction features with 3D-HOG features [23], we show to improve over their separate performance as well as over the state of the art.
CC.pdf (7.28 Mo) Télécharger le fichier
inria-00626929 , version 1 (27-09-2011)
inria-00626929 , version 2 (28-09-2011)
inria-00626929 , version 3 (28-09-2011)
inria-00626929 , version 4 (10-05-2012)
  • HAL Id : inria-00626929 , version 4
Alessandro Prest, Vittorio Ferrari, Cordelia Schmid. Explicit modeling of human-object interactions in realistic videos. [Technical Report] RT-0411, 2011. ⟨inria-00626929v4⟩
1081 Consultations
830 Téléchargements
