Wireless Mesh Networks: Energy - Capacity Tradeoff and Physical Layer Parameters - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Anis Ouni
Hervé Rivano
Fabrice Valois
This paper is focused on broadband wireless mesh networks based on OFDMA resource management, considering a realistic SINR model of the physical layer with a fine tuned power control at each node. A linear programing model using column generation leads to compute power efficient schedules with high network capacity. Correlation between capacity and energy consumption is analyzed as well as the impact of physical layer parameters - SINR threshold and path-loss exponent. We highlight that there is no significant tradeoff between capacity and energy when the power consumption of idle nodes is impor- tant. We also show that both energy consumption and network capacity are very sensitive to the SINR threshold variation.
PIMRC2011.pdf (156.1 Ko) Télécharger le fichier
inria-00629579 , version 1 (06-10-2011)
  • HAL Id : inria-00629579 , version 1
Anis Ouni, Hervé Rivano, Fabrice Valois. Wireless Mesh Networks: Energy - Capacity Tradeoff and Physical Layer Parameters. 22nd IEEE International Symposium on Personal, Indoor and Mobile Radio Communications (PIMRC), IEEE, Sep 2011, Toronto, Canada. ⟨inria-00629579⟩
165 Consultations
263 Téléchargements
