Data formats for phonological corpora - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2012
The goal of the present chapter is to explore the possibility of providing the research (but also the industrial) community that commonly uses spoken corpora with a stable portfolio of well-documented standardised formats that allow a high re-use rate of annotated spoken resources and, as a consequence, better interoperability across tools used to produce or exploit such resources.
PhonologicalCorpora_2011-10-08.pdf (1.09 Mo) Télécharger le fichier
inria-00630289 , version 1 (08-10-2011)
inria-00630289 , version 2 (03-03-2012)
  • HAL Id : inria-00630289 , version 1
  • ARXIV : 1110.1758
Laurent Romary, Andreas Witt. Data formats for phonological corpora. Jacques Durand and Ulrike Gut and Gjert Kristoffersen. Handbook of Corpus Phonology, Oxford University Press, 2012. ⟨inria-00630289v1⟩
203 Consultations
231 Téléchargements
