Large Deviation Multifractal Analysis of a Class of Additive Processes with Correlated Non-Stationary Increments - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2011
We consider a family of stochastic processes built from infinite sums of independent positive random functions on R+. Each of these functions increases linearly between two consecutive negative jumps, with the jump points following a Poisson point process on R+. The motivation for studying these processes stems from the fact that they constitute simplified models for TCP traffic. Such processes bear some analogy with L'evy processes, but are more complex since their increments are neither stationary nor independent. In [3], the Hausdorf multifractal spectrum of these processes were computed. We are interested here in their Large Deviation and Legendre multifractal spectra. These "statistical" spectra are seen to give, in this case, a richer information than the "geometrical" Hausdorf spectrum. In addition, our results provide a firm theoretical basis for the empirical discovery of the multifractal nature of TCP traffic.
v10.pdf (174.88 Ko) Télécharger le fichier
inria-00633195 , version 1 (17-10-2011)
inria-00633195 , version 2 (22-10-2012)
  • HAL Id : inria-00633195 , version 1
Jacques Lévy Véhel, Michal Rams. Large Deviation Multifractal Analysis of a Class of Additive Processes with Correlated Non-Stationary Increments. 2011. ⟨inria-00633195v1⟩
222 Consultations
521 Téléchargements
