Intrinsic and Extrinsic Analysis on Computational Anatomy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2006
Laurent Younes
  • Fonction : Auteur
  • PersonId : 875034
We present intrinsic and extrinsic methods for studying anatomical coordinates in order to perform statistical inference on random physiological signals F across clinical populations. To do so, we introduce generalized partition functions of the coordinates, (x), x 2 M, which are used to construct a random field model of F on M. In the intrinsic analysis, such partition functions are defined intrinsically for individual anatomical coordinate based on Courant's theorem on nodal analysis via self adjoint operators. On the contrary to the intrinsic method, the extrinsic method needs only one set of partition functions for a template coordinate system, and then applied to each anatomical coordinate system via transformation. For illustration, we give clinical studies on cortical thickness for each of these methods.
Autre [cs.OH]
Qiu_MFCA06.pdf (1.44 Mo) Télécharger le fichier
inria-00635889 , version 1 (26-10-2011)
  • HAL Id : inria-00635889 , version 1
Anqi Qiu, Laurent Younes, Michael I Miller. Intrinsic and Extrinsic Analysis on Computational Anatomy. 1st MICCAI Workshop on Mathematical Foundations of Computational Anatomy: Geometrical, Statistical and Registration Methods for Modeling Biological Shape Variability, Oct 2006, Copenhagen, Denmark. pp.68-79. ⟨inria-00635889⟩
Collections
MFCA MFCA06
66 Consultations
344 Téléchargements
