Cambiera: Collaborative Tabletop Visual Analytics
Cambiera is a tabletop system designed for co-located collaborative visual analytics. As a tabletop system, Cambiera encourages analysts to face each other around the tabletop to analyze large text document collections collaboratively. Cambiera allows analysts to search for documents and read them, organize documents on the tabletop, and to monitor each other's' work. The video illustrates the major collaborative features of Cambiera.
Interface homme-machine [cs.HC]
Isenberg_2011_CVA.pdf (368.88 Ko)
Télécharger le fichier
Format : Figure, Image
