Grid-wide neuroimaging data federation in the context of the NeuroLOG project. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Studies in Health Technology and Informatics Année : 2010
Michel Dojat
David Godard
  • Fonction : Auteur
  • PersonId : 763049
  • IdRef : 178139203
Grid technologies are appealing to deal with the challenges raised by computational neurosciences and support multi-centric brain studies. However, core grids middleware hardly cope with the complex neuroimaging data representation and multi-layer data federation needs. Moreover, legacy neuroscience environments need to be preserved and cannot be simply superseded by grid services. This paper describes the NeuroLOG platform design and implementation, shedding light on its Data Management Layer. It addresses the integration of brain image files, associated relational metadata and neuroscience semantic data in a heterogeneous distributed environment, integrating legacy data managers through a mediation layer.
neurolog_healthgrid_2010.pdf (569.03 Ko) Télécharger le fichier
inserm-00512799_edited.pdf (354.12 Ko) Télécharger le fichier
inserm-00512799 , version 1 (31-08-2010)
Franck Michel, Alban Gaignard, Farooq Ahmad, Christian Barillot, Bénédicte Batrancourt, et al.. Grid-wide neuroimaging data federation in the context of the NeuroLOG project.. HealthGrid'10, Jun 2010, Paris, France. pp.112-123, ⟨10.3233/978-1-60750-583-9-112⟩. ⟨inserm-00512799⟩
864 Consultations
724 Téléchargements
