Arterial spin labeling for motor activation mapping at 3T with a 32-channel coil: Reproducibility and spatial accuracy in comparison with BOLD fMRI. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue NeuroImage Année : 2011
Functional arterial spin labeling (fASL) is an innovative biomarker of neuronal activation that allows direct and absolute quantification of activation-related CBF and is less sensitive to venous contamination than BOLD fMRI. This study evaluated fASL for motor activation mapping in comparison with BOLD fMRI in terms of involved anatomical area localization, intra-individual reproducibility of location, quantification of neuronal activation, and spatial accuracy. Imaging was performed at 3T with a 32-channel coil and dedicated post-processing tools were used. Twelve healthy right-handed subjects underwent fASL and BOLD fMRI while performing a right hand motor activation task. Three sessions were performed 7days apart in similar physiological conditions. Our results showed an activation in the left primary hand motor area for all 36 sessions in both fASL and BOLD fMRI. The individual functional maps for fASL demonstrated activation in ipsilateral secondary motor areas more often than the BOLD fMRI maps. This finding was corroborated by the group maps. In terms of activation location, fASL reproducibility was comparable to BOLD fMRI, with a distance between activated volumes of 2.1mm and an overlap ratio for activated volumes of 0.76, over the 3 sessions. In terms of activation quantification, fASL reproducibility was higher, although not significantly, with a CVintra of 11.6% and an ICC value of 0.75. Functional ASL detected smaller activation volumes than BOLD fMRI but the areas had a high degree of co-localization. In terms of spatial accuracy in detecting activation in the hand motor area, fASL had a higher specificity (43.5%) and a higher positive predictive value (69.8%) than BOLD fMRI while maintaining high sensitivity (90.7%). The high intra-individual reproducibility and spatial accuracy of fASL revealed in the present study will subsequently be applied to pathological subjects.
inserm-00604941 , version 1 (30-06-2011)
Hélène Raoult, Jan Petr, Elise Bannier, Aymeric Stamm, Jean-Yves Gauvrit, et al.. Arterial spin labeling for motor activation mapping at 3T with a 32-channel coil: Reproducibility and spatial accuracy in comparison with BOLD fMRI.. NeuroImage, 2011, epub ahead of print. ⟨10.1016/j.neuroimage.2011.06.011⟩. ⟨inserm-00604941⟩
158 Consultations
0 Téléchargements
