Variational solution to the joint detection estimation of brain activity in fMRI - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Medical image computing and computer-assisted intervention : MICCAI ... International Conference on Medical Image Computing and Computer-Assisted Intervention Année : 2011
We address the issue of jointly detecting brain activity and estimating underlying brain hemodynamics from functional MRI data. We adopt the so-called Joint Detection Estimation (JDE) framework that takes spatial dependencies between voxels into account. We recast the JDE into a missing data framework and derive a Variational Expectation-Maximization (VEM) algorithm for its inference. It follows a new algorithm that has interesting advantages over the previously used intensive simulation methods (Markov Chain Monte Carlo, MCMC): tests on artificial data show that the VEM-JDE is more robust to model mis-specification while additional tests on real data confirm that it achieves similar performance in much less computation time.
Fichier sous embargo
Date de visibilité indéterminée
inserm-00635384 , version 1 (25-10-2011)
Lotfi Chaari, Florence Forbes, Thomas Vincent, Michel Dojat, Philippe Ciuciu. Variational solution to the joint detection estimation of brain activity in fMRI. MICCAI 2011 - 14th International Conference on Medical Image Computing and Computer-Assisted Intervention, Sep 2011, Toronto, Canada. pp.260-268, ⟨10.1007/978-3-642-23629-7_32⟩. ⟨inserm-00635384⟩
291 Consultations
2 Téléchargements
