Confirming the Explosive Outflow in G5.89 with ALMA - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Astrophysical journal letters Année : 2020
Luis A. Zapata
  • Fonction : Auteur
Paul T. P. Ho
  • Fonction : Auteur
Manuel Fernández-López
  • Fonction : Auteur
Estrella Guzmán Ccolque
  • Fonction : Auteur
Luis F. Rodríguez
  • Fonction : Auteur
José Reyes-Valdés
  • Fonction : Auteur
John Bally
  • Fonction : Auteur
Aina Palau
  • Fonction : Auteur
Masao Saito
  • Fonction : Auteur
Patricio Sanhueza
  • Fonction : Auteur
A. Rodríguez-González
  • Fonction : Auteur
The explosive molecular outflow detected decades ago in the Orion BN/KL region of massive star formation was considered to be a bizarre event. This belief was strengthened by the nondetection of similar cases over the years with the only exception of the marginal case of DR21. Here, we confirm a similar explosive outflow associated with the UCHII region G5.89-0.39 that indicates that this phenomenon is not unique to Orion or DR21. Sensitive and high angular resolution (∼0"1) Atacama Large Millimeter/submillimeter Array (ALMA) CO(2-1) and SiO(5-4) observations show that the molecular outflow in the massive star-forming region G5.89-0.39 is indeed an explosive outflow with an age of about 1000 yr and a liberated kinetic energy of 1046-49 erg. Our new CO(2-1) ALMA observations revealed over 30 molecular filaments, with Hubble-like expansion motions, pointing to the center of UCHII region. In addition, the SiO(5-4) observations reveal warmer and strong shocks very close to the origin of the explosion, confirming the true nature of the flow. A simple estimation for the occurrence of these explosive events during the formation of the massive stars indicates an event rate of once every ∼100 yr, which is close to the supernovae rate.
insu-03705175 , version 1 (27-06-2022)
Luis A. Zapata, Paul T. P. Ho, Manuel Fernández-López, Estrella Guzmán Ccolque, Luis F. Rodríguez, et al.. Confirming the Explosive Outflow in G5.89 with ALMA. The Astrophysical journal letters, 2020, 902, ⟨10.3847/2041-8213/abbd3f⟩. ⟨insu-03705175⟩
37 Consultations
0 Téléchargements
