Radial velocities and stellar population properties of 56 MATLAS dwarf galaxies observed with MUSE - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Astronomy and Astrophysics - A&A Année : 2023
Nick Heesters
  • Fonction : Auteur
Oliver Müller
  • Fonction : Auteur
Francine R. Marleau
  • Fonction : Auteur
Rubén Sánchez-Janssen
  • Fonction : Auteur
Mélina Poulain
  • Fonction : Auteur
Sungsoon Lim
  • Fonction : Auteur
Patrick R. Durrell
  • Fonction : Auteur
Dwarf galaxies have been extensively studied in the Local Group, in nearby groups, and selected clusters, giving us a robust picture of their global stellar and dynamical properties, such as their circular velocity, stellar mass, surface brightness, age, and metallicity in particular locations in the Universe. Intense study of these properties has revealed correlations between them, called the scaling relations, including the well-known universal stellar mass-metallicity relation. However, since dwarfs play a role in a vast range of different environments, much can be learned about galaxy formation and evolution through extending the study of these objects to various locations. We present MUSE spectroscopy of a sample of 56 dwarf galaxies as a follow-up to the MATLAS survey in low- to moderate-density environments beyond the Local Volume. The dwarfs have stellar masses in the range of M*/M = 106.1-109.4 and show a distance range of D = 14-148 Mpc, the majority of which (75%) are located in the range targeted by the MATLAS survey (10-45 Mpc). We thus report a 75% success rate for the semi-automatic identification of dwarf galaxies (79% for dwarf ellipticals) in the MATLAS survey on the subsample presented here. Using pPXF full spectrum fitting, we determine their line-of-sight velocity and can match the majority of them with their massive host galaxy. Due to the observational setup of the MATLAS survey, the dwarfs are located in the vicinity of massive galaxies. Therefore, we are able to confirm their association through recessional velocity measurements. Close inspection of their spectra reveals that ∼30% show clear emission lines, and thus star formation activity. We estimate their stellar population properties (age and metallicity) and compare our results with other works investigating Local Volume and cluster dwarf galaxies. We find that the dwarf galaxies presented in this work show a systematic offset from the universal stellar mass-metallicity relation toward lower metallicities at the same stellar mass. A similar deviation is present in other works in the stellar mass range probed in this work and might be attributed to the use of different methodologies for deriving the metallicity.
aa46441-23.pdf (2.37 Mo) Télécharger le fichier
insu-04178285 , version 1 (13-08-2023)
Paternité
Nick Heesters, Oliver Müller, Francine R. Marleau, Pierre-Alain Duc, Rubén Sánchez-Janssen, et al.. Radial velocities and stellar population properties of 56 MATLAS dwarf galaxies observed with MUSE. Astronomy and Astrophysics - A&A, 2023, 676, ⟨10.1051/0004-6361/202346441⟩. ⟨insu-04178285⟩
33 Consultations
22 Téléchargements
