The creation of a massive UCD by tidal threshing from NGC 936 - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Monthly Notices of the Royal Astronomical Society: Letters Année : 2023
Sanjaya Paudel
  • Fonction : Auteur
Sungsoon Lim
  • Fonction : Auteur
Mélina Poulain
  • Fonction : Auteur
Francine R. Marleau
  • Fonction : Auteur
Oliver Müller
  • Fonction : Auteur
Rubén Sánchez-Janssen
  • Fonction : Auteur
Patrick R. Durrell
  • Fonction : Auteur
Nick Heesters
  • Fonction : Auteur
Daya Nidhi Chhatkuli
  • Fonction : Auteur
Suk-Jin Yoon
  • Fonction : Auteur
We study a compact nucleus embedded in an early-type dwarf galaxy, MATLAS-167, which is in the process of disruption by the tidal force of the neighboring giant S0 galaxy, NGC 936, in a group environment. Using the imaging data of the MATLAS survey, we analyze the stellar tidal tail of MATLAS-167 and its central compact nucleus, designated as NGC 936_UCD. We find that NGC 936_UCD has a luminosity of Mg = -11.43 ±0.01 mag and a size of 66.5±17 pc, sharing the global properties of Ultra Compact Dwarf galaxies (UCDs) but significantly larger and brighter compared to the typical UCD populations observed in the Virgo cluster. By integrating the total luminosity of both the tidal stream and MATLAS-167, we estimate that the disrupted dwarf progenitor possesses a luminosity of Mg = -15.92 ±0.06 mag, a typical bright dE luminosity. With the help of the optical spectrum observed by the SDSS survey, we derive the simple stellar population properties of NGC 936_UCD: a light-weighted age of 5.6±0.7 Gyr and metallicity of [Z/H] = -0.83 ±0.3 dex. Our findings suggest that tidal threshing is a possible formation mechanism of bright UCD populations in close proximity to giant galaxies.
slad126.pdf (1.65 Mo) Télécharger le fichier
insu-04210804 , version 1 (04-04-2024)
Sanjaya Paudel, Pierre-Alain Duc, Sungsoon Lim, Mélina Poulain, Francine R. Marleau, et al.. The creation of a massive UCD by tidal threshing from NGC 936. Monthly Notices of the Royal Astronomical Society: Letters, 2023, ⟨10.1093/mnrasl/slad126⟩. ⟨insu-04210804⟩
37 Consultations
5 Téléchargements
